HiFi5 语音算法部署
部署算法需要完成以下四个方面的功能:
- 创建DSP算法组件目录及编写代码
- 在DSP上录音
- 使用算法加速库加速算法
- 核间通讯
- DUMP 数据到PC
创建DSP算法组件目录
创建并进入目录:
mkdir -p lichee/rtos-components/thirdparty/my_dsp_asr/src
mkdir -p lichee/rtos-components/thirdparty/my_dsp_asr/inc
cd lichee/rtos-components/thirdparty/my_dsp_asr/
编写 Kconfig 文件:
menu "my dsp asr"
config COMPONENTS_MY_DSP_ASR
bool "my dsp asr"
depends on ARCH_DSP
default n
help
to do
endmenu
修改 Kconfig 后建议重新 menuconfig
在 lichee/rtos-components/thirdparty/Kconfig 中追加:
source "components/common/thirdparty/my_dsp_asr/Kconfig"
编写 Makefile:
obj-y += src/my_dsp_asr.o
#self
CFLAGS += -Icomponents/common/aw/asr_demo/inc/
在 lichee/rtos-components/thirdparty/Makefile 中追加:
obj-$(CONFIG_COMPONENTS_MY_DSP_ASR) += my_dsp_asr/
编写基础代码
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include <console.h>
#include <FreeRTOS.h>
#include <task.h>
static void my_dsp_asr_thread(void *arg)
size_t loop = (size_t)arg;
printf("%s enter\n", __func__);
while (loop--) {
printf("%s %u\n", __func__, loop);
vTaskDelay(500 / portTICK_PERIOD_MS);
printf("%s exit\n", __func__);
vTaskDelete(NULL);
const char *thread_name = "my_dsp_asr_thread";
size_t stack_size = 0x4000;
size_t thread_priority = 1;
int cmd_my_dsp_asr(int argc, char *argv[])
size_t loop = 10;
TaskHandle_t handle = NULL;
if(xTaskCreate(my_dsp_asr_thread, thread_name, stack_size, (void *)loop, thread_priority, &handle) != pdPASS) {
printf("xTaskCreate %s failed!\n", thread_name);
FINSH_FUNCTION_EXPORT_CMD(cmd_my_dsp_asr, my_dsp_asr, my dsp asr);
./build.sh menuconfig,选择以下配置:
(会根据 Kconfig 的 select 字段自动选上依赖的组件)
检查是否编译进固件:
grep -r cmd_my_dsp_asr ./out/ --include=*.bin
可以看到:
lichee/dsp$ grep -r cmd_my_dsp_asr ./out/ --include=*.bin
Binary file ./out/r128s3/evb1/r128s2_dsp0_evb1.bin matches
Binary file ./out/r128s3/evb1/r128s2_dsp0_evb1_raw.bin matches
Binary file ./out/r128s3/evb1/r128s2_dsp0_evb1_xcc.bin matches
烧录固件即可在串口终端输入:
rpccli dsp my_dsp_asr
后期可以添加开机自启:
diff --git a/arch/sun20iw2/init-sun20iw2.c b/arch/sun20iw2/init-sun20iw2.c
index cfb2d45d..9b5c2a5d 100644
--- a/arch/sun20iw2/init-sun20iw2.c
+++ b/arch/sun20iw2/init-sun20iw2.c
@@ -160,5 +160,10 @@ void app_init(void)
rpdata_ctrl_init();
+#ifdef CONFIG_COMPONENTS_MY_DSP_ASR
+ int cmd_my_dsp_asr(int argc, char *argv[]);
+ cmd_my_dsp_asr(0, NULL);
+#endif
在DSP上录音
在Kconfig中添加:
bool "my dsp asr"
depends on ARCH_DSP
+ select COMPONENTS_AW_AUDIO_SYSTEM
default n
help
在Makefile中添加
#audio system
CFLAGS += -Icomponents/common/aw/AudioSystem/include/
参考代码:
#include "AudioRecord.h"
#define MS_PER_FRAME (10)
#define RECORD_RATE (16000)
#define RECORD_NAME "capture"
static const size_t record_time_ms = 10 * 1000;
static const uint32_t rate = RECORD_RATE;
static const uint8_t channels = 3;
static const uint8_t bitwidth = 16;
static int16_t record_buffer[RECORD_RATE * MS_PER_FRAME * 3 / 1000];
static void my_record_thread(void *arg)
tAudioRecord *pAudioRecord = NULL;
size_t time_ms = 0;
pAudioRecord = AudioRecordCreate(RECORD_NAME);
if (!pAudioRecord) {
printf("%s:%u error!\n", __func__, __LINE__);
// TODO
ret = AudioRecordSetup(pAudioRecord, rate, channels, bitwidth);
if (ret) {
// TODO
while (time_ms < record_time_ms) {
ret = AudioRecordRead(pAudioRecord, record_buffer, sizeof(record_buffer));
if (ret < 0) {
// TODO
time_ms += MS_PER_FRAME;
printf("%ums: read %d\n", time_ms, ret);
AudioRecordStop(pAudioRecord);
AudioRecordDestroy(pAudioRecord);
vTaskDelete(NULL);
使用算法加速库
本节只是代码演示,对于有HIFI5授权的客户可以向 Candence 获取 NatureDSP_Signal 和 xa_nnlib_api 的源码包,其中包含api的说明文档:
libxa_nnlib/doc/HiFi5-NNLib-ProgrammersGuide-API.pdfhifi5_library/doc/NatureDSP_Signal_Library_Reference_HiFi5.pdf
在Kconfig中添加:
bool "my dsp asr"
depends on ARCH_DSP
+ select COMPONENTS_XTENSA_HIFI5_NNLIB_LIBRARY
+ select COMPONENTS_XTENSA_HIFI5_VFPU_LIBRARY
default n
help
在Makefile中添加
CFLAGS += -I components/thirdparty/xtensa/hifi5_nn_v170_library/include
CFLAGS += -I components/thirdparty/xtensa/hifi5_vfpu_v200_library/include
(链接加速库的动作已经在 lichee/dsp/Makefile 中添加,无需重复添加)
FFT 参考代码:
#include <math.h>
#include "NatureDSP_Signal.h"
#include "xa_nnlib_api.h"
#ifndef PI
#define PI (3.141592653f)
struct cplxf_t {
float r;
float i;
static inline void make_src_cplxf_from_record_buffer(struct cplxf_t *output, int16_t *input, int N, uint8_t chs, uint8_t ch_index)
int i = 0;
for (i = 0; i < N; i++) {
output[i].r = input[i * chs + ch_index];
output[i].i = 0.0f;
// N*3/4 *twdstep
static inline void make_twd_cplxf(struct cplxf_t *output, const int N, const int twdstep)
int n, m;
for (n = 0; n < (twdstep * N) / 4; n++) {
for (m = 0; m < 3; m++) {
float phi = 2 * PI * (m + 1) * n / (twdstep * N);
output[n * 3 + m].r = cosf(phi);
output[n * 3 + m].i = sinf(phi);
int get_max(const struct cplxf_t *input_cplxf, int N)
float max = 0.0f;
float index = 0;
int i = 0;
float cur = input_cplxf[i].r * input_cplxf[i].r + input_cplxf[i].i * input_cplxf[i].i;
if (cur > max) {
max = cur;
index = i;
return index;
#define FFT_SIZE (1024)
static struct cplxf_t g_tmp_cplxf[FFT_SIZE];
static int record_data_handler(struct cplxf_t *output_cplxf, const struct cplxf_t *input_cplxf, const struct cplxf_t *twd_cplxf, int N)
if (N != FFT_SIZE) {
printf("%s incorrect data length: %d\n", __func__, N);
return -1;
memcpy(g_tmp_cplxf, input_cplxf, sizeof(g_tmp_cplxf));
fft_cplxf_ie(
(complex_float *)output_cplxf,
(complex_float *)g_tmp_cplxf,
(const complex_float *)twd_cplxf,
1,
FFT_SIZE);
在录音代码中添加:
if (ret) {
// TODO
+ static struct cplxf_t g_input_cplxf[FFT_SIZE];
+ static struct cplxf_t g_output_cplxf[FFT_SIZE];
+ static struct cplxf_t g_twd_cplxf[FFT_SIZE];
+ int N = rate * MS_PER_FRAME / 1000;
+ int twdstep = 1;
+ int max_index = -1;
+ make_twd_cplxf(g_twd_cplxf, N, twdstep);
if (ret < 0) {
// TODO
+ max_index = -1;
+ make_src_cplxf_from_record_buffer(g_input_cplxf, record_buffer, N, channels, 0);
+ if( !record_data_handler(g_output_cplxf, g_input_cplxf, g_twd_cplxf, N)) {
+ max_index = get_max(g_output_cplxf, N);
printf("%ums: read %d, max: %d\n", time_ms, ret, max_index);
核间通讯
代码仅供参考,不包含实际业务代码
在Kconfig中添加:
bool "my dsp asr"
depends on ARCH_DSP
+ select COMPONENTS_RPDATA
default n
help
在Makefile中添加
#rpdata
CFLAGS += -Icomponents/common/aw/rpdata/include/
由于核间通讯需要RV核配合,故还需编写RV端控制及接收数据的组件,可以参照编写DSP算法组件的方法编写: Kconfig:
menu "my rv asr"
config COMPONENTS_MY_RV_ASR
bool "my RV asr"
depends on !ARCH_DSP
default n
help
to do
endmenu
(注意是 !ARCH_DSP)
其它修改类似第一节内容,不再重复说明;
rv 端 menuconfig命令为 mrtos_menuconfig rv端执行代码不需要"rpccli dsp";
通用代码:
#include <rpdata.h>
struct my_rpd_t {
rpdata_t *rpd; // both
void *addr; // both
size_t buf_len; // send
void (*cb)(void *priv, void *data, unsigned int data_len); // recv
void *priv; // recv
struct my_rpd_cfg_t {
int dir; // both
const char *type; // both
const char *name; // both
void *priv; // recv
static void rpd_ch_deinit(struct my_rpd_t *hdl)
if (hdl->rpd) {
rpdata_t *rpd = hdl->rpd;
hdl->cb = NULL;
hdl->priv = NULL;
hdl->buf_len = 0;
hdl->addr = NULL;
hdl->rpd = NULL;
rpdata_destroy(rpd);
static int rpd_recv_ch_callback(rpdata_t *rpd, void *data, unsigned int data_len)
struct my_rpd_t *hdl = (struct my_rpd_t *)rpdata_get_private_data(rpd);
if (hdl->cb)
hdl->cb(hdl->priv, data, data_len);
static struct rpdata_cbs rpd_recv_cb = {
.recv_cb = rpd_recv_ch_callback,
static int rpd_recv_ch_init(struct my_rpd_t *hdl, struct my_rpd_cfg_t *cfg)
printf("recv rpd dir:%d, type:%s, name:%s\n", cfg->dir, cfg->type, cfg->name);
hdl->rpd = rpdata_connect(cfg->dir, cfg->type, cfg->name);
if (!hdl->rpd) {
printf("rpdata_connect failed!\n");
return -1;
hdl->addr = rpdata_buffer_addr(hdl->rpd);
if (!hdl->addr) {
printf("rpdata_buffer_addr failed!\n");
rpd_ch_deinit(hdl);
return -1;
hdl->cb = cfg->cb;
hdl->priv = cfg->priv;
rpdata_set_private_data(hdl->rpd, hdl);
rpdata_set_recv_cb(hdl->rpd, &rpd_recv_cb);
static int rpd_send_ch_init(struct my_rpd_t *hdl, struct my_rpd_cfg_t *cfg)
printf("send rpd dir:%d, type:%s, name:%s, buf_len:%u\n", cfg->dir, cfg->type, cfg->name, cfg->buf_len);
hdl->rpd = rpdata_create(cfg->dir, cfg->type, cfg->name, cfg->buf_len);
if (!hdl->rpd) {
printf("rpdata_create failed!\n");
goto err;
if (!hdl->addr) {
goto err;
hdl->buf_len = cfg->buf_len;
err:
rpd_ch_deinit(hdl);
return -1;
static int rpd_send(struct my_rpd_t *hdl, void *data)
memcpy(hdl->addr, data, hdl->buf_len);
rpdata_wait_connect(hdl->rpd);
return rpdata_send(hdl->rpd, 0, hdl->buf_len);
// RV to DSP 控制通道
#define RPD_CTL_TYPE ("RVtoDSPCtl")
#define RPD_CTL_NAME ("RVtoDSPCtlCh")
#define RPD_CTL_SIZE (4)
// DSP to RV 数据通道
#define RPD_DATA_TYPE ("DSPtoRVData")
#define RPD_DATA_NAME ("DSPtoRVDataCh")
#define RPD_DATA_SIZE (64)
DSP端代码:
static int g_run = 0;
static void my_rpd_dsp_recv_cb(void *priv, void *data, unsigned int data_len)
printf("%s recv:%d\n", __func__, data_len);
memcpy(&g_run, data, sizeof(g_run));
static void my_rpd_thread(void *arg)
struct my_rpd_t send_ch;
struct my_rpd_cfg_t send_cfg = {
.dir = 2,
.type = RPD_DATA_TYPE,
.name = RPD_DATA_NAME,
.buf_len = RPD_DATA_SIZE,
struct my_rpd_t recv_ch;
struct my_rpd_cfg_t recv_cfg = {
.dir = 2,
.type = RPD_CTL_TYPE,
.name = RPD_CTL_NAME,
.cb = my_rpd_dsp_recv_cb,
.priv = NULL,
unsigned char data[RPD_DATA_SIZE];
int i = 0;
for (i = 0; i < RPD_DATA_SIZE; i++) {
data[i] = '0' + 1;
g_run = 1;
printf("%s start\n", __func__);
if (rpd_send_ch_init(&send_ch, &send_cfg)) {
// TODO
if (rpd_recv_ch_init(&recv_ch, &recv_cfg)) {
// TODO
while(g_run) {
rpd_send(&send_ch, data);
rpd_ch_deinit(&recv_ch);
rpd_ch_deinit(&send_ch);
vTaskDelete(NULL);
RV端代码:
static void my_rpd_rv_recv_cb(void *priv, void *data, unsigned int data_len)
.dir = 3,
.buf_len = RPD_CTL_SIZE,
.dir = 3,
.cb = my_rpd_rv_recv_cb,
.priv = NULL,
g_run = 1;
// TODO
// TODO
while(1) {
int run = g_run;
rpd_send(&send_ch, &run);
if (!run)
break;
vTaskDelete(NULL);
RV 端和 DSP 端各自创建处理线程;
DSP 定时将数据发给 RV,RV 定时将运行标志发给 DSP;
RV 端修改 g_run 的值为 0,RV 将 g_run 的值发送给 DSP 后退出,DSP 收到 g_run 也将退出;
DUMP 数据到PC
DSP 端没有文件系统,所以数据需要先通过核间通讯发送给 RV 核,再由 RV 核通过某种方式保存或发送;
在 RV核上 可以使用 adb forward 实时将数据传输到 PC,或者也可以保存数据到 flash,然后使用 adb pull 到 PC;
本节的代码都是跑在RV核上的;
可以使用现有封装接口:
// file_path和port只需指定一个即可,另一个填NULL或0
// 指定file_path表示保存数据到flash,指定port表示提供adb传输数据到PC
void *data_save_create(const char *name, const char *file_path, int port);
void data_save_destroy(void *_hdl);
int data_save_request(void *_hdl, void *data, int size, int timeout_ms);
// 需要保存后续数据到另一文件时调用,用于分割音频数据
int data_save_flush(void *_hdl, int timeout_ms);
可以复制 lichee/rtos-components/aw/asr_demo/inc/data_save.h 和 lichee/rtos-components/aw/asr_demo/src/data_save.c 到自己的组件中使用,或者选上 CONFIG_COMPONENTS_ASR_DEMO 时可以直接使用;
通过标准文件操作接口保存到
flash或data_save组件指定文件路径保存到flash -
按以下步骤通过
adb forward传输数据到PC:
① 设备端:
reboot(重启设备)
(等待设备重启完成)
adb shell af -p [代码中填写的port] -r
② PC端:
adb forward tcp:11112 tcp:[代码中填写的port]
adb_record.py(或adb_record_3.py,2个文件都在lichee/rtos-components/aw/asr_demo/tools/,接收到的数据会保存在脚本执行目录下)
③ 设备端开始调用data_save接口创建通道并发送数据(可以参照第一节添加start和stop传输的命令)
