R128 模块
针对 R128 芯片,百问科技提供推出了一种型号模块,如下表所示
| 型号 | SoC | CPU0 | CPU1 | DSP | SRAM | LS-PSRAM | HS-PSRAM | Flash | DAC |
| R128-S2-N16R16 | R128-S2 | Arm M33 Star | C906 RISC-V | HIFI5 DSP | 1MByte | 8Mbyte | 8Mbyte | 16M NOR Flash | 2 Audio DAC LINEOUTLP/N LINEOUTRP/N |
R128-S2-N16R16
详细参数
- XuanTie 64Bit RISC-V [GCV] C906 CPU, Support Vector 0.7
- Arm M33 Star MCU
HiFi5 Audio DSP Xtensa LX7
1MB SRAM
- 8MB SiP OSPI HS_PSRAM@800MHz
- 8MB SiP OSPI LS_PSRAM@AHB Clock with DMA
16MB SiP QSPI NOR
RGB666, i8080, BT656, SPI Display up to 1024x768@60fps
- G2D 2D graphics acceleration
DVP up to 1920x1088, JPEG encoding 1920x1088, 1024x768@40fps
3 Audio ADC, 24Bit, 8kHz-96kHz, Support 4 DMICs
- 2 Audio DAC, 24Bit, 8kHz-384kHZ
- USB2.0 OTG
- 3 * UART, 2 * SPI, 2 * TWI, 8 * PWM, 1 * 12Bit 10 Channels ADC
- IR TX/RX, LEDC up to 1024 * WS2812
- ISO 7816 Card Reader
- Wi-Fi Compatible with IEEE 802.11 b/g/n 2.4GHz
Bluetooth 5.0 Dual Mode complies with V2.1/4.0/4.2/5.0, Support BR/EDR
25.5*18mm, IPEX ANT, ESP32-S3 Compatible Pinout
资源下载
- 硬件工程开源地址:https://oshwhub.com/gloomyghost/r128-module
- 电路原理图:SCH_R128-S2_2023-10-08.pdf
- PCB图:PCB_R128-S2_2023-10-08.pdf
- PCB:ProDocument_R128-S2-N16R16_2023-10-08.epro
- GERBER:SCH_R128-S2_2023-10-08.pdf
- ODB++:odb++_pcb_2023-10-08.zip
- 3D STEP:3D_R128-S2_2023-10-08.zip
- BOM:BOM_R128-S2-N16R16_R128-S2_2023-10-08.xlsx
- 点位图:PickAndPlace_R128-S2_2023-10-08.xlsx
- 引脚图:R128-S2-N16R16_PINOUT.svg
购买链接
引脚图
- 压缩后图片较模糊请下载高清引脚图:R128-S2-N16R16_PINOUT.svg
