芯片参数
芯片特性
- XuanTie 64 bit RISC V C 906 CPU
- HiFi5 Audio DSP
- Arm M33 Star MCU
- Memories
- 1MB SRAM
- SiP 8 MB/16 MB Flash
- 8 MB H S PSRAM in R128 S 1
- 8 MB LS PSRAM & 8 MB HS PSRAM in R128 S2
- 32 MB HS PSRAM in R128 S3
- 2048 bit efuse
- Image and Graphics
- Supports Graphic 2D accelerator with rotate, mixer, and 4 layers
- Supports RGB output interface, up to 1024 x 768 @60 fps
- Supports display engine
- Video Input
- 8 bit parallel CSI interface
- Supports both online and offline mode for JPEG encoder
- Supports JPEG encoder, 1920 x 108 8
- Analog Audio Codec
- 2 DAC channels 24 bit audio codec for R128 S1 and R128 S2
- 1 DAC channel 24 bit for R128 S3
- 3 ADC channels
- Supports USB audio playback
- Up to 119 dB SNR during DAC playback path (signal through DAC and lineout with A weighted filter)
- Up to 98 dB SNR during ADC record path (signal through PGA and ADC with A weighted filter)
- One I2S/TDM/PCM external inte rface (I2S0
- Security Engine
- Symmetrical algorithm: AES, DES, 3DES
- Hash algorithm: MD5, SHA1, SHA224, SHA256, SHA384, SHA512, HMAC
- Asymmetrical algorithm: RSA512/1024/2048bit
- S upports TRNG
- External Peripherals
- One USB 2.0 DRD
- Up to 3 UART controllers (UART 0, UART1, UART2)
- Up to 2 SPI controllers (SPI0, SPI1)
- Up to 2 TWIs
- One CIR RX and one CIR TX
- Up to 8 PWM channels (PWM[ 7 0
- Up to 7 GPADC input channels (R128 S1 & R128 S2)/8 channels (R128 S3)
- One LEDC used to control the external intelligent control LED lamp
- Package
- QFN80, 0.35 mm pitch, 8 mm x 8 mm body
GPIO 复用
| Pin Name | GPIO Group | IO Type | Function 2 | Function 3 | Function 4 | Function 5 | Function6 | Function7 | Function8 | Function 14 |
| PA0 | GPIOA | I/O | IR-RX | PWM7 | TWI0-SCL | TWI1-SCL | LCD-VSYNC | LCD-D2 | PA-EINT0 | |
| PA1/FEL0 | GPIOA | I/O | IR-TX | FEM-CTRL1 | IR-RX | TWI0-SDA | TWI1-SDA | LCD-D3 | PA-EINT1 | |
| PA2/FEL1 | GPIOA | I/O | SPI1-CS |
DMIC-DATA0 | JTAG-RV-TMS | SDC-DATA1 | I2S-LRCLK | JTAG-DSP-TMS | LCD-D4 | PA-EINT2 |
| PA3 | GPIOA | I/O | SPI1-CLK |
DMIC-DATA1 | JTAG-RV-TDI | SDC-DATA0 | I2S-BCLK | JTAG-DSP-TDI | LCD-D5 | PA-EINT3 |
| PA4 | GPIOA | I/O | SPI1-MOSI |
DMIC-DATA2 | UART0-TX | SDC-CLK | I2S-DIN | PWM1 | LCD-D6 | PA-EINT4 |
| PA5 | GPIOA | I/O | SPI1-MISO |
DMIC-DATA3 | JTAG-RV-TDO | SDC-CMD | I2S-DOUT | JTAG-DSP-TDO | LCD-D7 | PA-EINT5 |
| PA6 | GPIOA | I/O | SPI1-HOLD |
DMIC-CLK | UART0-RX | SDC-DATA3 | I2S-MCLK | LCD-CLK | LCD-D14 | PA-EINT6 |
| PA7 | GPIOA | I/O | SPI1-WP |
OWA-IN | JTAG-RV-TCK | SDC-DATA2 | JTAG-DSP-TCK | LCD-HSYNC | LCD-D13 | PA-EINT7 |
| PA8 | GPIOA | I/O | UART0-RX | OWA-OUT | PWM0 | OWA-IN | TWI1-SCL | FEM-CTRL2 | LCD-D12 | PA-EINT8 |
| PA9 | GPIOA | I/O | UART0-TX | PWM1 | LEDC | TWI1-SDA | LCD-DE | LCD-D15 | PA-EINT9 | |
| PA10 | GPIOA | I/O | UART2-RTS | IR-RX | PWM2 | TWI1-SCL | LCD-D11 | PA-EINT10 | ||
| PA11/WUPIO0 | GPIOA | I/O | UART2-CTS | IR-TX | PWM3 | TWI1-SDA | 32KOSCO | FEM-CTRL1 | LCD-D10 | PA-EINT11 |
| PA12/WUPIO1/ LXTAL-IN | GPIOA | I/O | UART2-TX | TWI0-SCL | UART2-RTS | IR-RX | SPI1-CS/DBI-CSX | LCD-VSYNC | LCD-D18 | PA-EINT12 |
| PA13/WUPIO2/ LXTAL-OUT | GPIOA | I/O | UART2-RX | TWI0-SDA | UART2-CTS | IR-TX | SPI1-CLK/DBI-SCLK | LEDC | LCD-D19 | PA-EINT13 |
| PA14/WUPIO3 | GPIOA | I/O | PWM0 | SPI1-MOSI |
UART2-RX | SIM-DATA | UART1-RTS | TWI1-SCL | LCD-D20 | PA-EINT14 |
| PA15 | GPIOA | I/O | PWM1 | SPI1-HOLD |
UART2-TX | SIM-CLK | UART1-CTS | TWI1-SDA | LCD-D21 | PA-EINT15 |
| PA16 | GPIOA | I/O | TWI0-SCL | OWA-IN | TWI1-SCL | UART0-TX | IR-RX | UART2-TX | SWD-TMS | PA-EINT16 |
| PA17 | GPIOA | I/O | TWI0-SDA | OWA-OUT | TWI1-SDA | UART0-RX | IR-TX | UART2-RX | SWD-TCK | PA-EINT17 |
| PA18/WUPIO4 | GPIOA | I/O | I2S-MCLK | IR-RX | IR-TX | SPI1-MOSI |
NCSI-HSYNC | LCD-VSYNC | PA-EINT18 | |
| PA19/WUPIO5 | GPIOA | I/O | I2S-LRCLK | UART1-RTS | PWM4 | DMIC-DATA0 | SPI1-HOLD |
NCSI-VSYNC | LCD-HSYNC | PA-EINT19 |
| PA20/WUPIO6 | GPIOA | I/O | I2S-BCLK | UART1-CTS | PWM5 | DMIC-DATA1 | SPI1-WP |
NCSI-PCLK | LCD-CLK | PA-EINT20 |
| PA21/WUPIO7 | GPIOA | I/O | I2S-DIN | UART1-RX | PWM6 | DMIC-DATA2 | SPI1-MISO |
NCSI-MCLK | LCD-DE | PA-EINT21 |
| PA22/WUPIO8 | GPIOA | I/O | I2S-DOUT | UART1-TX | PWM7 | DMIC-DATA3 | LEDC | NCSI-D0 | PA-EINT22 | |
| PA23/WUPIO9 | GPIOA | I/O | I2S-MCLK | DCXO-PUP-OUT | SWD-SWO | DMIC-CLK | TWI0-SCL | PWM0 | NCSI-D1 | PA-EINT23 |
| PA24 | GPIOA | I/O | SDC-DATA3 | SPI0-MISO | PWM4 | UART2-RX | TWI0-SDA | SIM-DATA | NCSI-D6 | PA-EINT24 |
| PA25 | GPIOA | I/O | SDC-CMD | SPI0-WP | PWM5 | JTAG-M33-TDO | JTAG-RV-TDO | SIM-CLK | NCSI-D5 | PA-EINT25 |
| PA26 | GPIOA | I/O | SDC-DATA0 | SPI0-CLK | PWM6 | JTAG-M33-TDI | JTAG-RV-TDI | LEDC | NCSI-D3 | PA-EINT26 |
| PA27 | GPIOA | I/O | SDC-DATA1 | SPI0-HOLD | PWM7 | JTAG-M33-TMS | JTAG-RV-TMS | SIM-DET | NCSI-D2 | PA-EINT27 |
| PA28 | GPIOA | I/O | SDC-DATA2 | SPI0-CS | FEM-CTRL1 | JTAG-M33-TCK | JTAG-RV-TCK | SIM-RST | NCSI-D7 | PA-EINT28 |
| PA29 | GPIOA | I/O | SDC-CLK | SPI0-MOSI | FEM-CTRL2 | UART2-TX | PWM1 | LEDC | NCSI-D4 | PA-EINT29 |
For R128-S1/S2
| PB0/ADC0 | GPIOB | I/O | UART0-TX | TWI1-SCL | IR-RX | UART2-RTS | PWM2 | NCSI-HSYNC | PB-EINT0 | |
| PB1/ADC1 | GPIOB | I/O | UART0-RX | TWI1-SDA | IR-TX | UART2-CTS | PWM3 | NCSI-VSYNC | PB-EINT1 | |
| PB2/ADC2 | GPIOB | I/O | PWM2 | SPI1-MISO |
TWI1-SCL | SIM-RST | UART1-RX | UART2-RTS | LCD-D23 | PB-EINT2 |
| PB3/ADC3 | GPIOB | I/O | PWM3 | SPI1-WP |
TWI1-SDA | SIM-DET | UART1-TX | UART2-CTS | LCD-D22 | PB-EINT3 |
| PB4/ADC4 | GPIOB | I/O | PWM4 | LCD-DE | PB-EINT4 | |||||
| PB14/ADC6 | GPIOB | I/O | UART1-TX | NCSI-PCLK | PB-EINT14 | |||||
| PB15/ADC7 | GPIOB | I/O | UART1-RX | PWM0 | NCSI-MCLK | PB-EINT15 |
For R128-S3
| PB4/ADC4 | GPIOB | I/O | UART1-RTS | SDC-CLK | SPI0-CS | PWM4 | LCD-DE | PB-EINT4 | ||
| PB5/ADC5 | GPIOB | I/O | UART1-CTS | SDC-DATA1 | SPI0-MOSI | PWM5 | PB-EINT5 | |||
| PB6 | GPIOB | I/O | UART1-TX | SDC-DATA0 | SPI0-CLK | PWM6 | PB-EINT6 | |||
| PB7 | GPIOB | I/O | UART1-RX | SDC-DATA3 | SPI0-HOLD | PWM7 | PB-EINT7 | |||
| PB14/ADC6 | GPIOB | I/O | UART1-TX | SDC-DATA2 | SPI0-WP | NCSI-PCLK | PB-EINT14 | |||
| PB15/ADC7 | GPIOB | I/O | UART1-RX | SDC-CMD | SPI0-MISO | PWM0 | NCSI-MCLK | PB-EINT15 |
信号描述
| Signal Name | Description | Type |
| HS-PSRAM PHY IO | ||
| VDD12-PSM | Power Supply of PSRAM | P |
| RF0 | ||
| ANT0 | Antenna of RF0 | A |
| HXTAL-IN | Digital Compensated Crystal Oscillator Input | AI |
| HXTAL-OUT | Digital Compensated Crystal Oscillator Output | AO |
| VCC33-RFPA0 | Power Supply of RF0 Input | P |
| VCC18-TX0 | Power Supply of RF0 Input | P |
| VCC18-ANA0 | Power Supply of RF0 Analog/RF Input | P |
| Note: HXTAL is the system clock of the whole chip, which includes the clocks required by the RF module and other modules. | ||
| RF1 | ||
| ANT1 | Antenna of RF1 | A |
| VCC33-RFPA1 | Power Supply of RF1 Input | P |
| VDD18-TX1 | Power Supply of RF1 Input | P |
| VCC18-ANA1 | Power Supply of RF1 Analog/RF Input | P |
| PMU | ||
| VIN-VBAT | VBAT System Power Input | P |
| VDD-RTC | RTC Power | P |
| VDD-AON | VDD-AON Power Supply of AON Domain | P |
| VDD-DSP | VDD-DSP Power Supply of DSP | P |
| LX | Power Supply of DCDC Output | P |
| EXT-LDO33 | VDD-3V3 Power Output of 3.3V | P |
| VDD-SENSE | Power Supply of Internal LDO Input | P |
| VDD-SYS | Power Supply for System | P |
| RESET | ||
| CHIP-PWD | System Power on Reset | I |
| RSTN | System Reset | I |
| USB | ||
| VC33-USB | Power Supply of USB | P |
| USB-DM | USB Data Signal DM | A I/O |
| USB-DP | USB Data Signal DP | A I/O |
| Audio Codec | ||
| MBIAS | Master Analog Microphone Bias Voltage Output | AO |
| MICIN1P | Microphone Positive Input 1 | AI |
| MICIN1N | Microphone Negative Input 1 | AI |
| MICIN2P | Microphone Positive Input 2 | AI |
| MICIN2N | Microphone Negative Input 2 | AI |
| MICIN3P | Microphone Positive Input 3 | AI |
| MICIN3N | Microphone Negative Input 3 | AI |
| VRA1 | Reference Voltage | AO |
| VRA2 | Reference Voltage | AO |
| AGND | Analog Ground | G |
| AVCC | Power Supply for Analog Part | P |
| LOUTRN | Stereo Lineout Output Right Negative Channel | AO |
| LOUTRP | Stereo Lineout Output Right Positive Channel | AO |
| LOUTLP | Stereo Lineout Output Left Positive Channel | AO |
| LOUTLN | Stereo Lineout Output Left Negative Channel | AO |
| Power | ||
| VCC-IO1 | Power Supply of IO1 Domain | P |
| VCC-IO2 | Power Supply of IO2 Domain | P |
| CIR Receiver | ||
| IR-RX | Consumer Infrared Receiver | I/O |
| CIR Transmitter | ||
| IR-TX | Consumer Infrared Transmitter | I/O |
| SPI | ||
| SPI0-CS | SPI0 Chip Select Signal, Low Active | I/O |
| SPI0-CLK | SPI0 Clock Signal | I/O |
| SPI0-MOSI | SPI0 Master Data Out, Slave Data In | I/O |
| SPI0-MISO | SPI0 Master Data In, Slave Data Out | I/O |
| SPI0-WP | SPI0 Write Protect, Low Active | I/O |
| SPI0-HOLD | SPI0 Hold Signal | I/O |
| SPI1-CS |
SPI1 Chip Select Signal, Low Active/Chip Select Signal, Low Active | I/O |
| SPI1-CLK |
SPI1 Clock Signal/Serial Clock Signal | I/O |
| SPI1-MOSI |
SPI1 Master Data Out, Slave Data In/Data Output Signal | I/O |
| SPI1-MISO |
SPI1 Master Data In, Slave Data Out/Data Input Signal/Tearing Effect Input/DCX pin is the select output signal of data and command | I/O |
| SPI1-HOLD |
SPI1 Hold Signal/ DCX pin is the select output signal of data and command/When DBI operates in dual data lane format, the RGB666 format 2 can use WRX to transfer data | I/O |
| SPI1-WP |
SPI1 Write Protect, Low Active/ Tearing Effect Input | I/O |
| UART | ||
| UART0-RX | UART0 Data Receive | I/O |
| UART0-TX | UART0 Data Transmit | I/O |
| UART1-RTS | UART1 Data Request to Send | I/O |
| UART1-CTS | UART1 Data Clear to Send | I/O |
| UART1-RX | UART1 Data Receive | I/O |
| UART1-TX | UART1 Data Transmit | I/O |
| UART2-RTS | UART2 Data Request to Send | I/O |
| UART2-CTS | UART2 Data Clear to Send | I/O |
| UART2-RX | UART2 Data Receive | I/O |
| UART2-TX | UART2 Data Transmit | I/O |
| PWM | ||
| PWM[7:0] | Pulse Width Modulation Output Channel0 | I/O |
| TWI | ||
| TWI0-SCL | TWI0 Serial CLOCK Signal | I/O |
| TWI0-SDA | TWI0 Serial Data Signal | I/O |
| TWI1-SCL | TWI1 Serial CLOCK Signal | I/O |
| TWI1-SDA | TWI1 Serial Data Signal | I/O |
| I2S | ||
| I2S-LRCLK | I2S sample rate clock | I/O |
| I2S-BCLK | I2S Bit Rate Clock | I/O |
| I2S-DIN | I2S Serial Data Input | I/O |
| I2S-DOUT | I2S Serial Data Input | I/O |
| I2S-MCLK | I2S Master Clock | I/O |
| SDIO | ||
| SDC-CMD | SDIO Command Signal | I/O |
| SDC-DATA[3:0] | SDIO data Signal | I/O |
| SDC-CLK | SDIO clock Signal | I/O |
| DMIC | ||
| DMIC-DATA[3:0] | Digital MIC Data input signal | I/O |
| DMIC-CLK | Digital Microphone Clock Output | I/O |
| OWA | ||
| OWA-IN | One Wire Audio Input | I/O |
| OWA-OUT | One Wire Audio Output | I/O |
| JTAG | ||
| JTAG-RV-TMS | RISC-V JTAG TMS signal | I/O |
| JTAG-DSP-TMS | DSP JTAG TMS signal | I/O |
| JTAG-RV-TDI | RISC-V JTAG TDI signal | I/O |
| JTAG-DSP-TDI | DSP JTAG TDI signal | I/O |
| JTAG-RV-TDO | RISC-V JTAG TDO signal | I/O |
| JTAG-DSP-TDO | DSP JTAG TDO signal | I/O |
| JTAG-RV-TCK | RISC-V JTAG TCK signal | I/O |
| JTAG-DSP-TCK | DSP JTAG TDO signal | I/O |
| JTAG-M-TDO | ARM M33 JTAG TDO signal | I/O |
| JTAG-M-TDI | ARM M33 JTAG TDI signal | I/O |
| JTAG-M-TMS | ARM M33 JTAG TMS signal | I/O |
| JTAG-M-TCK | ARM M33 JTAG TCK signal | I/O |
| SWD | ||
| SWD-SWO | Serial Wire Debug data signal | I/O |
| SWD-TMS | Serial Wire Debug TMS signal | I/O |
| SWD-TCK | Serial Wire Debug clock signal | I/O |
| System | ||
| FEM-CTRL1 | Front End Module Control, TX-EN | I/O |
| FEM-CTRL2 | Front End Module Control, RX-EN | I/O |
| SIM-DATA | Smart Card data signal | I/O |
| SIM-CLK | Smart Card clock signal | I/O |
| SIM-DET | Smart Card detect signal | I/O |
| SIM-RST | Smart Card reset signal | I/O |
| DCXO | ||
| DCXO-PUP-OUT | Power Control of External DCDC | I/O |
| LEDC | ||
| LEDC | Intelligent control LED signal output | I/O |
| CLOCK | ||
| 32KOSCO | 32.768K clock fanout | I/O |
| LCD | ||
| LCD-VSYNC | LCD Vertical Sync | I/O |
| LCD-D[7:2] | LCD Data Output | I/O |
| LCD-D[15:10] | LCD Data Output | I/O |
| LCD-D[23:18] | LCD Data Output | I/O |
| LCD-CLK | LCD CLOCK | I/O |
| LCD-HSYNC | LCD Horizontal Sync | I/O |
| LCD-DE | LCD Data Output Enable | I/O |
| NCSI | ||
| NCSI-HSYNC | DVP-CSI Horizontal Sync signal | I/O |
| NCSI-VSYNC | DVP-CSI Vertical Sync signal | I/O |
| NCSI-PCLK | DVP-CSI pixel clock signal | I/O |
| NCSI-MCLK | DVP-CSI master clock signal | I/O |
| NCSI-D[7:0] | DVP-CSI data signal[7:0] | I/O |
| Interrupt | ||
| PA_EINT[29:0] | GPIO A Interrupt | I/O |
| PB_EINT[4:0] | GPIO B Interrupt | I/O |
| PB_EINT[15:14] | GPIO B Interrupt | I/O |
R128-S1/R128-S2 与 R128-S3 的引脚区别
| Ball Number | R128-S1/R128-S2 Pin | R128-S3 Pin |
| 19 | RSTN | VIN-VBAT |
| 20 | VIN-VBAT | LX |
| 21 | LX | VDD-SENSE |
| 22 | VDD-SENSE | VCC33-USB |
| 23 | VCC33-USB | USB-DM |
| 24 | USB-DM | USB-DP |
| 25 | USB-DP | VDD-SYS |
| 26 | VDD-SYS | VDD12-PSM |
| 27 | VDD12-PSM | PA16 |
| 28 | PA16 | PA17 |
| 29 | PA17 | PA15 |
| 30 | PA15 | PA27 |
| 31 | PA27 | PA26 |
| 32 | PA26 | PA29 |
| 33 | PA29 | PA25 |
| 34 | PA25 | PA24 |
| 35 | PA24 | PA28 |
| 36 | PA28 | PB7 |
| 39 | PB14/ADC6 | PB6 |
| 40 | PB15/ADC7 | PB5/ADC5 |
| 41 | PB1/ADC1 | PB14/ADC6 |
| 42 | PB0/ADC0 | PB15/ADC7 |
| 43 | PB4/ADC4 | PB0/ADC0 |
| 44 | VDD-SYS | PB1/ADC1 |
| 45 | VCC-IO1 | PB4/ADC4 |
| 46 | MBIAS | VDD-SYS |
| 47 | MICIN1P | VCC-IO1 |
| 48 | MICIN1N | MBIAS |
| 49 | MICIN2P | MICIN1P |
| 50 | MICIN2N | MICIN1N |
| 51 | MICIN3P | MICIN2P |
| 52 | MICIN3N | MICIN2N |
| 53 | VRA1 | MICIN3P |
| 54 | VRA2 | MICIN3N |
| 55 | AGND | VRA1 |
| 56 | AVCC | VRA2 |
| 57 | LOUTLN | AGND |
| 58 | LOUTLP | AVCC |
| 59 | LOUTRP | LOUTLN |
| 60 | LOUTRN | LOUTLP |
